Aceq
PC Specification: Windows 10, GTX 960M, i5-5200 8GB Ram
Minecraft crash when I start action.
Wed Jun 14, 2017 4:38 pm
I have no problems when I am playing minecraft but whenever I start action it just crash. And it stops when I have closed down action. Minecraft doesn't crash when I am recording with Action only when I start action. Can someone help me what the problem is? It would be appreciated. I have the full version of Action.
Wartorn
PC Specification: Win 10, i7-6700HQ, GTX 1070M, 32GB RAM
Re: Minecraft crash when I start action.
Thu Jun 22, 2017 12:50 am
Yeah, I've also been getting this, for me at least it seems the issue occurs when I force Minecraft (Java) to use my Nvidia GPU rather than the Intel i7 GPU.
If I launch Minecraft with it set to use the default i7 GPU then it works, but obviously, this isn't ideal because my framerate suffers a lot. I saw that on the forum a few other people had this problem in an older version of Action! and it was fixed, but it seems to be an issue again.
I saw mentioned elsewhere that Java versions can cause a problem and to install 64bit, however, I have the latest Java SE 8u131 64bit installed, as well as the latest 32bit version which is required for some software I also have installed on my system. I have Minecraft using the 64bit version of Java and not the 32bit.
I experience Java crashing always with modded Minecraft, however, vanilla Minecraft also freezes for several seconds whenever I open Action! or upon launch, if Action! is already open.
If I have Action! closed then I have no problems what-so-ever with either Minecraft or Java.
I've tried reinstalling my graphics drivers (which I have the latest ones installed), Java and Action! but still have this issue.
Wartorn
Wed Jun 28, 2017 5:10 pm
So I tested this on another system I have, which has the exact same drivers and software versions installed and it worked fine. However, the main differences between the systems are, the working system has two GeForce 980s in SLI and the onboard i7 GPU is turned off.
So it would seem that the issue appears on systems that have both the Intel GPU and a dedicated GPU active.
Rayhan
PC Specification: Windows 10 Enterprise 64bit
Mon Jul 03, 2017 10:11 am
I'm also having this problem, I even made a new thread about it
Micatchu
PC Specification: Windows 10, Nvidia GPU, i7
Fri Jun 01, 2018 11:07 am
Hi. So I just got an new laptop with exactly this problem. Has anyone found a solution yet?, thx Micatchu
Tue Jun 05, 2018 5:39 am
Andy Roberts
PC Specification: Windows 7
Sat Aug 10, 2019 6:16 am
Try out the given below fixes to fix Minecraft crashing issues:
1. Restart your computer.
2. Repair corrupted system files.
3. Update Minecraft.
4. Remove all MODS of Minecraft.
5. Update Graphics Card Drivers.
6. Organize correct settings.
AdvancedGP
PC Specification: I7 8th gen, NVIDEA GTX 1080, 16GB Ram
Action! crashing minecraft
Fri Sep 20, 2019 11:29 pm
I just bought action, but whenever i have action and Minecraft up at the same time, Minecraft crashes. My GPU and CPU are at their latest update. what is going on?
Windows 10 (Action running on compatibility with windows 7)
16GB ram
NVIDEA GTX 1080
Intel I7 8th gen
Ouny
PC Specification: i7 GTX 1060 Windows 10
Thu Oct 10, 2019 9:38 pm
Hello ! I fond the sollution ! Let's see it right here : https://www.youtube.com/watch?v=vLh7_NPkwKw&t=1s ! (It's in french but it's easy to follow)
digiskills
PC Specification: PC Specification: i7 GTX 1060 Windows 10
Sun Sep 06, 2020 6:46 pm
The same thing keeps happening to me and I just go into task manager and close the two Minecraft launcher tabs again. I'm not sure why this keeps happening, but I hope it gets patched soon. I just tried it worked the first time yesterday! https://techloris.com/minecraft-not-responding/ But when I logged on today it stopped working.
