Rayhan
PC Specification: Windows 10 Enterprise 64bit
Minecraft stops responding after opening action
Mon Jul 03, 2017 10:10 am
Hey this is my first forum post :D
Before I installed windows 10 creators edition update, action worked fine for me (I can record games and such and upload them to YouTube) but after the win10 creators update, the problem occurs which my Minecraft stops responding after I open up action but after I close action the game started responding again just like normal, I need this problem fixed because I need to go back to uploading vids to YouTube again! Please reply if u have any way to fix :)
Sorry for my bad english it's not my normal language
Here are my PC specs
Win10 Enterprise 64bit
GT740M
Intel i3 on 1.80GHz
Feel free to ask anything else and I will try my best to answer them
Vivic42
PC Specification: Windows 10, Nvidia GeForce 1050, I5 7300
Action! + Minecraft = Crash
Tue Jul 04, 2017 3:09 pm
I encounter a little problem right now and I come here to see if a person has a solution.
When I throw minecraft then action! Or conversely, my minecraft crash while I have not even started recording yet.
I have a good enough config amp sufficient:
- Nvidia GeForce 1050
- Intel i5 7300 Processor
- 8 G of Ram
Thanks in advance for your solution! ;-)
Sorry for the spelling I'm French x)
Re: Action! + Minecraft = Crash
Wed Jul 18, 2018 10:14 am
Hello, please check out this topic: viewtopic.php?f=36&t=46459
JaneWatkins
PC Specification: 14.0 inch, 1920 x 1080 Pixels, IPS, 60 H
Fri Aug 04, 2023 2:09 am
Sometimes it has many mistakes, it's inevitable, try to find and fix it.
tedmichael
PC Specification: 11th Gen Intel(R) Core(TM) i5-11320H @
Wed Sep 11, 2024 3:26 pm
Hello! It sounds like you're experiencing an issue with Minecraft crashing when using Action! for recording. Based on your description, it seems like your hardware is sufficient, but there might be a conflict between the recording software and Minecraft.
Here are a few suggestions you can try:
1. Update your drivers: Ensure that both your Nvidia GeForce drivers and any other necessary system drivers are up to date.
2. Check Minecraft version compatibility: If you're using a modded version or a Minecraft APK on Android, ensure it is compatible with your recording software. Some APK versions might have limitations when it comes to running third-party apps like screen recorders.
3. Lower game settings: Try lowering your Minecraft settings or changing the resolution. It might reduce the load on your CPU and GPU when running both applications.
4. Disable overlays: Programs like Action! may use overlays, which can sometimes interfere with Minecraft. Try disabling any overlays in your recording software.
5. Test with another recording tool: If possible, try using a different recording software to see if the issue persists.
Hopefully, these tips help resolve the issue!
