Henn
PC Specification: i5 4690K GTX 970 Windows 10
Black bars when using the adjustable window [Solved]
Mon Jul 10, 2017 2:36 pm
I purchased the software and I am having some troubles. I want to record a window. The resolution of the window is:
765 x 503
I am using the record mode where you can specify the exact dimensions you want to record and I am using the "snapping" feature. The problem is, when I record, the video has black bars. Is there a way to make the recording stretch to fill in the black bars. I believe it needs to be 16:9. I'm not too technical when is comes to recordings so sorry if any information is unclear, I'll be happy to explain further if need be.
Thanks.
Re: Black bars when using the adjustable window
Wed Jul 18, 2018 10:10 am
765 x 503
Thanks.
Hello, there is no black bars in your video. Video players play videos in 16:9 aspect ratio, so video, that has different aspect ratio, does not fit in player window and there are empty spaces.
xingyuboss
PC Specification: i7, amd 530
Streched 4:3 CSGO resolution
Sat Aug 24, 2019 10:14 am
Hey, I want to record & Livestream CSGO in 4:3 resolution. I want the image stretched on the screen without black bars. I can't find a way to fit the gameplay/recording to the screen, how do I get it right in Action!?
Help is appreciated... :? :roll:
Return to “General Topics”
