Disby
PC Specification: AMD CPU, Rx 470, Windows 10
Action! Recording Problem
Fri Jul 21, 2017 8:25 pm
Everything I start to record with action! It's doing fine, but when I end the recording with action it reboots and doesn't save any of the settings I recently applied to it. (I was playing minecraft)
I've tried changing the file destination.
I've tried not using Multi-Core rendering
I've tried to not use Hardware acceleration.
If anyone knows how to fix this please help!
Specs :
AMD FX(tm)-8300 Eight-Core Processor
16 gb Ram DDR3
Radeon rx 470 8GB DDR4
Windows 10
Re: Action! Recording Problem
Tue Jul 25, 2017 6:04 am
Go to Audio Settings tab and disable "Record system sounds" option and see if issue persists.
