thatspammidude
PC Specification: Windows 10 Pro, Intel i7-
PUBG - Can't record with reshade
Tue Jul 25, 2017 9:12 am
Hi all!
Maybe you've heard reshade. If not and you are playing PUBG, try it out! It's makes the game look sooo much better, doesn't hit the FPS (at least for me) and is allowed by the PUBG developers!
The thing is: This programm runs on top of the game, to sharpen/color the image. If you run reshade, Action! doesn't register the game anymore and recording is not possible.
Does anyone know a workaround?
Thanks guys!
Xethgnur
PC Specification: Intel i5, GTX-1080, Win10
Re: PUBG - Can't record with reshade
Fri Sep 01, 2017 10:19 pm
I have the same issue.
So far, my work around has been to record the entire screen, since PUBG is in Borderless Windowed Mode anyways at Maximized. But this is highly inefficient since its recording my entire desktop. Even with the new feature to specify the app I want to record, it still seems to lag, since I think its trying to hide the EVERYTHING else thats going on in the background on top of PUBG, which is already fairly intensive on the rig... :? :?
It would be nice if Action! recognized Reshader, maybe that would help with the fps drops...
CerdoHD
PC Specification: AMD R9 200 Series, Windows 10 64bit
Mon Sep 18, 2017 8:08 pm
The problem is still there. Please do something, its so anoying using Shadowplay.
