AdydasNZ
PC Specification: i7 2600k Win1, ASUS GTX980 Strix GPU 8GB
Audio Delay 1-2 Seconds
Wed Jul 26, 2017 7:53 am
Hi All
I have googled, searched forums till my eyes hurt nothing to resolve this, every setting tried - what am i missing?
i7 2600k
GTX980 Strix GPU
Running nVidia surround but single screen 1920x1080 when using action.
8GB memory Corsair Dominiator
SSD hard disks for target and OS / games
Logitec G930 wireless head set
Software AudioSwitch that allows me to keyboard shortcut between monitor or headset for audio does run but shouldnt have any effect here.
Sound is played into Logitec 930 for gaming.
Action 2.5.5.0
Licensed to me
Using Timeshift so have to use MP4 settings as below
Issue i have is that audio is delayed by 1-2 seconds when output, for example point a gun at a wall in a FPS and shoot you hear the sound 2 seconds after you see a hole in the wall - example video could be provided if required but i am sure you get the idea.
Audio records fine for both in game sound and the microphone but the in game sound as highlighted from the time-shift is offset by 2 seconds approx, in 'normal' recording using AVI files sound is fine so it has to be to do with encoding into MP4 but all setings, quality sliders changed - nothing.
So what is it?
Image 1
action 1.JPG (54.95 KiB) Viewed 15207 times
action 2.JPG (45.94 KiB) Viewed 15207 times
action 3.JPG (50.01 KiB) Viewed 15207 times
Re: Audio Delay 1-2 Seconds
Wed Jul 18, 2018 9:11 am
Please install the latest Action! version: https://mirillis.com/download-action
If the issue persists then disable or uninstall AudioSwitch and see if that helps.
