zzuru
PC Specification: windows 10
can't record system and microphone at the same time
Sat Jul 29, 2017 10:28 am
So basically when i try to record some gameplay it will record either my system audio or my microphone i changed the settings many times and it didn't change anything, the only thing that changes which audio i record is the part in the screenshot here http://prntscr.com/g1rg41 if i change it to system sounds it changes and same with the microphone but there's another tab with the same settings, and i change that to a different one than the first one it records only the first one.
Re: can't record system and microphone at the same time
Tue Aug 01, 2017 5:50 am
go to Action! main tab and select "Microphone" checkbox and set it to "Always Record".
In Audio Settings tab select your speakers/headphones and in Microphone Settings tab select your microphone.
Make sure that mic volume is not set to 0% and "Record microphone into separate audio track" feature is disabled.
zzuru
Tue Aug 01, 2017 8:05 pm
It didn't work :/ It still recorded only the speaker sounds not the micrphone
