actioniscoolocean
PC Specification: pc
complete uninstall
Sat Aug 05, 2017 9:22 pm
How? Settings are saved somewhere outside Action folder but where?
For example twitch settings automatically added after uninstall reinstall..
Re: complete uninstall
Wed Aug 09, 2017 5:47 am
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
