Pascal
PC Specification: I7 7700k, gainward GTX 1060, Win10 x64
High CPU load in Idle
Sun Aug 06, 2017 6:26 pm
Hi, sometimes, when action is started, it uses a lot of my CPU. Sometimes it goes down to 0% when I start Recording but most of the time, it stays in high load, so that i have to close it, to be able to play the game. Sometimes everything goes well. Im not able to figure out when which situation is present or what causing this issue. Any ideas!?
Action 3.5.4
Re: High CPU load in Idle
Wed Aug 09, 2017 5:48 am
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
Pascal
Tue Aug 15, 2017 11:12 am
Thanks,
I think that resolved the issue. Tested it since you replied to me. BUT .. now I have another issue. I have massive framedrop in PUBG, also in "idle". For example, I have 2 screens, left screen is the game running, right screen is Action! startet. When I now klick the mouse in the right screen, the small HUD from Action! says 70-90 FPS. When I klick now the left screen, to focus the game, it drops to 20-25 FPS WITHOUT recording yet. Yesterday, I tried Action! after 2 hours gaming again, and had no framedrops. Nothing changed in the meanwhile :?:
If you want me to post some settings, just tell me.
Thanks
Pascal
Action 3.5.4
Pascal
Fri Aug 18, 2017 7:03 pm
Think I can "fix" it. When I click "active monitor" and back to "game mode" the frames stays as they should!
Action 3.5.4
