CVROY
PC Specification: AMD9590FX, GEFORCE 980 TI SC, WIN 10X64
Teamspeak 3 voices not being heard
Sun Aug 13, 2017 6:47 pm
When using action to record games All sounds are clear and fine except other people on Teamspeak 3. They are 98% inaudible. You can hear something but you can't really tell what it is. All game sounds are loud and clear, My voice is perfectly fine as I assume it is taking it directly from the mic and not through Teamspeak 3. Is there an issue with ACTION! getting the sound from Teamspeak 3 making it so you cannot hear the other players??? As a side note, when I use Geforce Experience to record game footage All sounds are perfectly audible. You can clearly hear the other players in Teamspeak 3. Could you folks take a look at this and get it remedied because I like your software a lot better however I would like to capture other peoples voices in game as well.
CVROY
Re: Teamspeak 3 voices not being heard
Mon Oct 09, 2017 1:48 am
This is still an issue even after the most recent update. Cannot hear other teamspeak 3 voices in recording done with ACTION!
DEVS, any work on this???
CVROY
Wed Oct 11, 2017 8:18 pm
The record what you hear #24 in your product feature list is not true until it records teamspeak 3 voices with all the system audio... as it so claims to do.
This has been an issue for months actually. Please look into rectifying it, that would be awesome!
CVROY
Wed Oct 25, 2017 1:30 am
Still cannot get it to play incoming teamspeak 3 voices. Absolutely nothing works. Teamspeak 3 must be sent to audio in some fashion that ACTION! cannot utilize properly. I'd love to use this program however I am currently stuck using Geforce Experience because it captures all audio (truly). They even just implemented multi track recording options so you can separate your voice etc. You guys better get a move here, that's all I'm saying...
CVROY
Sat Oct 28, 2017 3:47 am
Seriously, does anyone else have this issue with ACTION! + Teamspeak 3?
