Santos
PC Specification: Win 10 , amd phenom ii x4 965 , 660gt
EXTREME CPU Usage 75%
Thu Aug 17, 2017 9:03 pm
Hi , i got a big Problem. i have installed Action after a Long time again on my win 10. I have a amd phenom ii x4 965 with 4x 3,4 ghz , 12gb ram ddr3 , nvidia 660gt and when i hit"record" the cpu usage is going from 2-4% to 70-75% and i do nothing else recording my Desktop while iam doing nothing.
does anybody have a solution to this ? i dont think that it is normal. thanks in advance.
Re: EXTREME CPU Usage 75%
Fri Aug 18, 2017 6:07 am
Make sure that hardware acceleration is on.
Go to Action! main tab and select NVIDIA NVENC from hardware acceleration list.
If your issue still persists then please report this to our technical support via support@mirillis.com
Santos
Fri Aug 18, 2017 8:17 am
i dont have the option to choose
