MemeSage
PC Specification: Gtx 1080 ti
Action Hardware Acceleration + Adobe Premiere Pro = Broken
Tue Aug 22, 2017 6:13 am
If you have your Hardware Acceleration set to "Nvidia NVENC HEVC" while you have Adobe Premiere Pro open. Action will Crash and Create a Corrupt Video file, causing Action to Crash over and over and over again till you delete that file, and end the Action Process in the task manager. It will also not show any option for Hardware Acceleration till you close and re-open Adobe premiere pro.
This is a Real Problem for me, Because I need Hardware Acceleration in order to record Gameplay bits with out lag, But I also need my video editing Software open at the same time.
Benigno
PC Specification: Windows 10
Re: Action Hardware Acceleration + Adobe Premiere Pro = Broken
Wed Jan 24, 2018 7:43 am
Hi MemeSage, the same thing happens to me. Did you fix yours?
changwan
PC Specification: intel
Wed Apr 15, 2020 4:28 am
Could you please check if normal (non hardware accelerated) MP4 format can be properly imported to your editing software? I use adobe Premiere Pro , some Photoshop, for most of my Video editing work on PC. I have a XP-Pen Star 06 digital painting tablet to work on my projects . it works on photoshop photo retouching and Premiere Pro video editing programs .
