LaurDonuts
PC Specification: Windows 10, NVIDIA 920M, Intel i3-5005u
Action not working with dedicated GPU (nvidia)
Sun Aug 27, 2017 12:34 am
Hi there!
I have a Nvidia 920m and I can't play any game with it and record at the same time. I have to disable my dedicated GPU from Device Manager in order for Action to open. When I have both display adapters enabled, it doesn't work. A message pops-up saying " Action stopped working ". If any of you can give me a good solution, I've been searching the internet for hours and there's nothing that can really help me.
-PS: I TRIED TO MAKE ACTION WORK WITH INTEGRATED GRAPHICS FROM THE NVIDIA CONTROL PANEL, IT STILL DOESN'T WORK. - found the tutorial on the site.
My specifications: Windows 10, Nvidia 920m, Intel i3-5005u.
kingsleytailors
PC Specification: i3 2350, IntelHD3000, W7x64
Re: Action not working with dedicated GPU (nvidia)
Tue Sep 12, 2017 6:15 am
i think Integrated graphic isnot powerful, you should try external GPU
hillclimb
PC Specification: Windows 8.1
Mon Oct 02, 2017 8:10 am
Thanks for your page! I hope you will continue to have similar posts to share with everyone! Thank you for sharing them.
Return to “General Topics”
