soul0reaper
PC Specification: i7-930, ASUS DIRECTCU 5850, Win 7 64 bit
Cannot smoothly play .mkv with GPU Acceration
Sat Aug 21, 2010 6:56 pm
Hi, I'm giving your splash player a try and it seems that on some .mkvs whenever I turn on GPU acceration the image stutters, pixelates and flashes green.
Nielo TM
Re: Cannot smoothly play .mkv with GPU Acceration
Sat Aug 21, 2010 7:18 pm
I have the same issue with MPC as well when using DXVA. I think issue maybe related to ATI GPU/Driver
Joco1114
Sun Aug 22, 2010 2:30 pm
It must be the driver. I have an nVidia GTX 260 and plays smoothly.
Home Theater:
Synology NAS 1010+ | 9TB HDD
soul0reaper
Thu Aug 26, 2010 2:08 am
Joco1114 while ati drivers are generally crap, it doesn't necessarily "must" be that. I don't want to get a jet engine for directx 11 :P
Its only on selected mkv so I'm guessing its a codec issue. I can play certain mkvs just fine.
Another interesting thing I've noticed is that the GPU sign doesn't show up when I'm playing avi files.
Joco1114
Thu Aug 26, 2010 6:08 am
:P You're right!
Home Theater:
vivan
Fri Aug 27, 2010 1:06 pm
soul0reaper wrote:Another interesting thing I've noticed is that the GPU sign doesn't show up when I'm playing avi files.
I guess that's because almost nobody using AVC (H.264) with avi container (e.g. because avi doesn't support all features of AVC).
There should be codec Xvid/Divx/Mpeg-4 ASP so it isn't possible to playback with hardware acceleration on your card (full acceleration is only for VC-1 and AVC). But this is so old and "easy" codec, that any CPU can handle this.
PS Vita, Nokia N8
Nielo TM
Sat Aug 28, 2010 7:08 pm
soul0reaper wrote:Joco1114 while ati drivers are generally crap, it doesn't necessarily "must" be that. I don't want to get a jet engine for directx 11 :P
It depends on the video codec as MKV is just a container.
If you play the came file in MPC in DXVA mode, the same artifact will occur ;)
soul0reaper
Sun Aug 29, 2010 2:00 am
They do indeed.
Hmm might be a problem with my ati card then.
can any1 try to play this file http://www.filesonic.com/en/file/119322 ... 9a2b7_.mkv with gpu acceleration one and see if you get artifacts?
Joco1114
Sun Aug 29, 2010 11:00 am
Every player on my computer worked correctly with the dancing girls video! :)
Not a HD quality, but with Splash it was enjoyable without any picture error.
Codec: FFDSHOW or built in (GPU acc where possible)
Players: Splash Pro, VLC, PotPlayer
Home Theater:
Sotos Ch
PC Specification: C2D E8400, HD5770, Windows 7 (64bit)
Sun Aug 29, 2010 11:32 pm
They do indeed.
Without gpu acceleration
With gpu acceleration
