NikosD
PC Specification: Windows 7 x64 - ATI 5750 - E7300
WMV and UHD H.264 GPU acceleration - Not working
Fri Aug 27, 2010 6:02 am
Hello
You have the fastest video player I have ever tried with GPU acceleration enabled
My system is:
Win 7 x64 - Radeon 5750 - Catalyst 10.8
I don't have:
1) WMV acceleration - at all
2) UHD H.264 (4096 x 2304) acceleration - at all
ATI and you have declared H.264 Level 5.1 support, up to 4K
It doesn't seem to work as WMV too.
Sample here:
Joco1114
Re: WMV and UHD H.264 GPU acceleration - Not working
Fri Aug 27, 2010 7:00 am
I cant play this sample only with VLC. Nice sizes... :)
Home Theater:
Synology NAS 1010+ | 9TB HDD
NikosD
Fri Aug 27, 2010 9:05 am
Joco1114 wrote:I cant play this sample only with VLC. Nice sizes... :)
You CAN or you CAN'T ?
With VLC when you enable GPU acceleration you get a nice Blue screen of death (BSOD).
VLC can not handle at all those files in GPU.
Only in CPU, but the point is the GPU (DXVA) acceleration
Joco1114
Fri Aug 27, 2010 10:34 am
Sorry I can't write, but I CAN play it with VLC. I have GPU acc. on, I didnt get BSOD, but the playing was hmm... like a slideshow. :)
I have Win7 x64, Nvidia GTX 260.
Home Theater:
NikosD
Fri Aug 27, 2010 1:25 pm
Joco1114 wrote:Sorry I can't write, but I CAN play it with VLC. I have GPU acc. on, I didnt get BSOD, but the playing was hmm... like a slideshow. :)
Understood.
So Nvidia cards try to play them in GPU, but they can't. Nice try!
We get BSOD
Sotos Ch
PC Specification: C2D E8400, HD5770, Windows 7 (64bit)
Fri Aug 27, 2010 3:23 pm
Playing this video file with VLC I only get a green screen. With Splash Pro nothing happens, with MPC-HC I get a BSOD, with Windows Media Player also a BSOD. Only BSPlayer plays this file without a significant problem. All this in Windows 7 64bit, with an ATI HD5770 and the latest Catalyst, 10.8.
Joco1114
Fri Aug 27, 2010 4:32 pm
You should have to try something:
I installed ffdshow_rev3529_20100811_clsid_x64.exe for my x64 Win7. After this I can play the file with MPC-HC and with PotPlayerx64 without any problem with sound and smooth video.
Dont forget to set MPC-HC to VMR9.
Home Theater:
Sotos Ch
Fri Aug 27, 2010 5:28 pm
Thanks! I installed the 32bit version of ffdshow (I'm using the 32bit version of mpc-hc) and now it plays this clip with the vmr9 and the haali renderer. In both cases without dxva, enabling dxva (by using the EVR renderer) gives immediately a BSOD. PotPlayer plays also this file, using YUY2 (software mode, no dxva).
NikosD
Fri Aug 27, 2010 6:15 pm
The real deal is, if someone can play it in DXVA mode (GPU accelerated).
With ATI or Nvidia and with any combination of codecs and players.
I'm waiting for your results
