JoDi
PC Specification: Win7 pro/home UK/DE
Splash Pro can´t open AVCD files with metadata. [FIXED]
Sat Aug 28, 2010 10:24 am
Nice player, I love it.
If I enter meta-data to a AVCHD file, SplashPro can´t play it. The original file works well.
Re: Splash Pro can´t open AVCD files with metadata.
Mon Sep 20, 2010 4:49 pm
What version did you try?
Please try latest Splash PRO 1.2.2.
JoDi
Tue Oct 05, 2010 5:36 am
I tried version 1.1.0.0
The same problem with 1.2.3.0
JoDi
Fri Dec 31, 2010 12:46 pm
Problem resolved. Now it works.
SplashPro 1.4.0.0
Re: Splash Pro can´t open AVCD files with metadata. [FIXED]
Sun Apr 10, 2011 10:14 pm
Thanks for a feedback!
From version 1.4.0 Splash PRO fully supports AVCHD format playback.
From version 1.4.0 Splash PRO is certified AVCHD player.
