Splash_Smart
PC Specification: GT 720
Splash 2.1 bad sync Windows Red-stone 3
Tue Oct 24, 2017 2:24 am
Hi there...
I've already send a email to technical support but still no reply form them.
So,
Found Splash 2.1 problem with Windows Red Stone 3. So my problems is in Windows Red Stone 3, lags on HEVC/X265 videos. Lag means voice and video is not sync correctly. Voice is moving forward faster than video. This is keep happening when "Motion 2" is enabled and without motion 2, video is playing normally and everything is fine.
To clear the issue i have installed Windows red stone 3 on another computer and checked HEVC/X265 movies with splash 2.1. It's happening on both computers.
Any recommendation?
I am using Splash for over 3 years now. This isn't any hardware issue becasue it used work really well until windows upgrade to red-stone 3 for over 3 years.
Thank you!
sensei
PC Specification: i5-7200U, 8GB RAM, Win 10 x64
Re: Splash 2.1 bad sync Windows Red-stone 3
Wed Oct 25, 2017 7:49 pm
The devs don't give a damn so it's high time we, Splash users, switched to some alternative software.
MirceaForce
PC Specification: i7 5960x gtx 1070 windows 10 v1709 x64
Sat Oct 28, 2017 8:58 am
sensei wrote:The devs don't give a damn so it's high time we, Splash users, switched to some alternative software.
i think they go down with splash ...damm :(((
Splash_Smart
Sat Oct 28, 2017 12:30 pm
Yes this is very bad. Splash is very good player. Most common players doesn't have video quality like splash and not even close. :) :) :)
But if mirillis can't continue its' software's why don't they sell there company or software's to another who can handle/improve them nicely.
JimmyTheX
PC Specification: FX-8320,GeForce970,16GB RAM,SSD,W10Pro
Tue Oct 31, 2017 7:20 pm
I use Splash for so long, but when I upgrade my Windows 10 Pro to Fall Creators Update, Splash 2.1 is going crazy to play any kind of video files. Sound and video is out of sync and when disable Motion, sync is good but video doesn't play smooth. Come on Mirillis, don't leave us like that ! Please fix.
Thank you.
sensei
Sun Nov 05, 2017 7:38 pm
The worst thing is that they totally ignore our complaints.
Splash_Smart
Mon Nov 06, 2017 12:59 am
sensei wrote:The worst thing is that they totally ignore our complaints.
True 100%. They don't care us actually. :!: :!: :!:
Return to “Splash 2.0”
