Comboe
PC Specification: GTX 980m Windows 10 Intel I7-6700hq
Windows 10 and Action crashing with minecraft
Sat Aug 19, 2017 3:53 pm
Hello, I have a problem with action. Whenever I open Minecraft and then run action it crashes minecraft, making it impossible for me to record. I really need help with this because it's starting to frustrate me. Any solutions for this?
Thyme1250
PC Specification: i5-5200U, GF830M, Version 10.0.15063
Minecraft crashes when opening Action
Tue Oct 24, 2017 3:45 pm
I really like this screen recorder.But Minecraft always crashes when Action is running. It wasn't happened before. Recording other games like Overwatch or Far Cry 4 works fine.
Re: Minecraft crashes when opening Action
Tue Jul 17, 2018 10:40 am
Hello, please check out this post: viewtopic.php?f=36&t=46459
ICreativeCrum
PC Specification: i7-7700 GTX1050 16GB-DDR4
Action freezes other apps
Fri Nov 30, 2018 10:43 pm
When I launch action, it makes most of my games freeze, like minecraft, scrap mechanic, etc. Not any software/apps though. Not sure why this is happening and I've looked everywhere for a solution, someone please help.
Leticiapoole
Sat Aug 02, 2025 6:55 am
Hey, I had the same problem when using Action with Minecraft on Windows 10! 🚨 It turns out that the cause is not only from the software but also related to the graphics card driver or compatibility settings.
Everyone try:
1️⃣ Run Action in Administrator mode.
2️⃣ Update or rollback the GPU driver.
3️⃣ Turn off Hardware Acceleration if available.
4️⃣ Or try using Game Recording mode instead of Screen Recording.
Has anyone tried a more effective way? Share it for everyone to refer to!
holeioonline
PC Specification: Windows 10
Tue Mar 17, 2026 2:53 am
You can try **opening Action! first before running Minecraft, updating your graphics card drivers, running Action with administrator privileges, disabling other overlays (like Discord or GeForce), or switching to screen recording mode instead of Game Mode to avoid conflicts that could cause the game to crash during recording.**
