sneakyb
PC Specification: Intel i7, Windows 10
Action! with OBS on multi-monitor PC
Wed Oct 25, 2017 11:40 am
I am attempting to capture game action with Action!. I have a PC with Windows 10, and stream with OBS on a multi-monitor PC. I would like Action! to capture the game (Steam/DirectX) footage which is on the center monitor, but Action! is capturing the OBS window which is running on the second monitor.
Action! is set to capture the game, because I am hoping to use Action! to use TimeShift to capture recent action.
Is there a way to direct Action! to capture the game, and not what OBS is "seeing"?
Thanks!
Re: Action! with OBS on multi-monitor PC
Thu Oct 26, 2017 5:54 am
if you go to the game Action! will focus on it.
Minimize OBS, go to the game so Action! focus on it, minimize the game, enable Time-Shift and get back to game.
marthawil710
PC Specification: CPU model
Fri Oct 27, 2017 3:44 am
I confirm that I have the same problem and better again try to install it..
