albertein123
PC Specification: cpu i5 Gpu intel HD520 Win10
Mouse cursor size with high res screen
Thu Oct 26, 2017 8:32 am
I have a problem recording the screen on my surface pro; The mouse cursor is fine when recording, but ends up huge on the video. I think it's related to very high res screen on the surface. I need to record in 720p because i'm recording a tutorial aimed at regular laptop, with low res screen.
I've tried to set the resolution of the surface to a lower resolution (720p), I've tried on a second screen (1080p) , with resolution set to 720p , i've tried different combination, but i'm getting this huge cursor or a broken video with three streched images.. I've played with the windows scale coeficient.. without any luck..
Anyone with the same experience who found a way?
Thanks!
Re: Mouse cursor size with high res screen
Tue Jul 17, 2018 10:36 am
Thanks!
Please update Action! to the latest version. If the issue persists then open Display Settings and change dpi to 100%.
Desktop 7-17-2018 12-33-44 PM-615.jpg (126.12 KiB) Viewed 6507 times
