Donadelli
PC Specification: Core i7 3770, GTX 1080Ti, Windows 10 64b
Audio out of sync
Fri Oct 27, 2017 4:25 am
Hello!
I would like to report and at the same time get help for a problem I have when recording a gameplay with Action where the end result gets the audio out of sync.
I've noticed that usually the problem occurs with gameplays that go beyond 20 minutes in length.
I decided to create this topic by go version, come version and this problem persists.
Thank you in advance for your attention.
Re: Audio out of sync
Fri Oct 27, 2017 5:45 am
Please report your issue to our technical support via support@mirillis.com
Donadelli
Fri Oct 27, 2017 3:17 pm
Piotr wrote:Please report your issue to our technical support via support@mirillis.com
Ok, thank you
eleczo
PC Specification: Ubunto
Wed Nov 15, 2017 10:08 am
Did you got complete solution for it? I think probably you got. Because suggestion came from admin end.
Return to “General Topics”
