user82
PC Specification: Q6600,Ati HD-4850
Possible Bug: Motion2 destroys Deinterlacing
Wed Sep 01, 2010 9:28 pm
Hi!
i expirienced that Motion2(2x or 60p) messed up the deinterlacing compeltely on a 1080p Clip(GPU Decoding on ATI)
perhaps there is some bug that causes this!
Thanks for lookign into it
user
From Tiesto Bluray, 1080i(Screenshot made in non-fullscreen but it looks similar)
Nielo TM
Re: Possible Bug: Motion2 destroys Deinterlacing
Wed Sep 01, 2010 9:34 pm
Splash Pro 1.1 does use the GPU when Motion2 (MCFI) is enabled. However, de-interlacing is automatically disabled when Motion2 is enabled.
Mirillis team are working on a solution to overcome this issue.
user82
Wed Sep 01, 2010 9:39 pm
Nielo TM wrote:Splash Pro 1.1 does use the GPU when Motion2 (MCFI) is enabled. However, de-interlacing is automatically disabled when Motion2 is enabled.
oh i didnt have that knowledge, thanks !
