Shed
PC Specification: Intel i7, Asus Strix 1070, Windows 10
Multi Channel sound with Adobe Premier
Sat Nov 11, 2017 11:38 am
Hello there,
First, excuse my english :) not my main tongue.
I Have two questions :
1. I have recorded some games with Action! and everything is fine except that when I export the .avi file into Adobe Premier for editing I'm able to see only one audio channel and not two.
I set up Action! for recording both my microphone and my sound game.
What's the problem here ?
2. I would like to know if it's possible to record sepratly the sound of the game, whitout the voice of Discord and my voice and into another file only the voices of Discord and mine.
Actually I have to channels : Discord voices and the game + my voice and I would like : All the voice (Discord and mine) into on channel and the game into a second channel.
Thanks for your answers :)
Re: Multi Channel sound with Adobe Premier
Tue Nov 21, 2017 7:02 am
1. Close sony Vegas, go to Sony Vegas location, open "FileIO Plug-Ins" folder and rename folder "compoundplug" to something else.
2. If you set Discord to use audio device different than the system deafult then you can record Discord and microphone into separate file by using Audio Recording feature.
DrunkMonk74
Wed Nov 22, 2017 4:31 pm
Piotr wrote:1. Close sony Vegas, go to Sony Vegas location, open "FileIO Plug-Ins" folder and rename folder "compoundplug" to something else.
OP said for point 1 that he was using Adobe Prem Pro. I have the same issue in Prem Pro. Was it a typo saying "Sony Vegas"? If not is there a solution for Prem Pro?
