avalon
PC Specification: I7 8700K Titan x maxwell windows 10 1703
Streaming Discontinuous
Tue Nov 14, 2017 6:51 pm
Hello, I'm not good at language but will try to communicate with you as well as possible. I'm having trouble stopping the stream and starting a new stream, resulting in discontinuity in the stream. I tried to find the cause of the problem but could not find it.
Re: Streaming Discontinuous
Thu Nov 23, 2017 6:57 am
Probably the stream bitrate is set to high and streaming service cuts you off. Try lowering bitrate and see if that helps.
