Deniz
PC Specification: Windows 10 Home, i5-2500, Nvidia GTX 660
active desktop region is not recording
Thu Nov 23, 2017 11:35 pm
Update: Uninstalling 2.3 and installing 2.8 solved the issue.
Recording the active desktop region is no longer working. Last used it some Months ago.
I can select a region but when I press the record icon nothing happened. Also Screenshot Icon did not work.
I experimented with the resolution and snap-icon and NOW if I start Action! and go to the active desktop I dont even see the recording region anymore!
1. How to reset the settings so I can see the recording region?
2. How to record with active desktop again?
Recording the whole desktop with F9 works, also OpenGl/DirektX works.
Action
Action Version: 2.3.0.0
Recording Resolution: ---
Recording Mode: Region
Windows and Hardware
OS: Windows 10
Video Card: NVIDIA GTX 660
Video Driver Version: DirectX 12 388.13
CPU brand and model: Intel Core i7-4790
Motherboard brand and model: ----
Memory: 16 GB
Monitor Resolution: 1920x1080 only one Monitor
Problem Description
Game/App Problem: active desktop region
Error Type: record button not functional, active desktop region not visible any more after trying to fix the problem
Video Editor: ---
Description: record button not functional, active desktop region not visible any more after trying to fix the problem.
Re: active desktop region is not recording
Wed Jul 11, 2018 8:12 am
Action
OS: Windows 10
Memory: 16 GB
Problem Description
Video Editor: ---
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
