Royk
PC Specification: windows 10, 5800K, 32gb DDR4, 1070GTX
Does Action! requeres an internet to function? (104 error)
Thu Dec 21, 2017 1:47 pm
Dear users,
I am using this program for some months now and in overall happy.
I am an illustrator and sometimes i need to record my work. Today, there where some problems with the internet connection. A total black out for a whole region here in The Netherlands. I was offline for some time. No problem, plenty of work i can do and not have to worry about emails etc.
Here is the thing.. Action! was not able to start. An error 104 was prompting on my screen and the program stopped working. So no internet, no Action! ?
It that is the case, how can i counter this?
Resetting the Host file is not changing the need for internet i guess?
Roy
Re: Does Action! requeres an internet to function? (104 erro
Fri Dec 22, 2017 7:01 am
if you are experiencing technical issues with internet connection, and Action! doesn't work because of that, then the best way to solve this porblem is to disable internet connection entirely. Just open network and internet settings and disable network adapter.
