HFS10dude
PC Specification: Quad with lotsa grunt!!!
Problems playing XVID "SOLVED"
Wed Sep 08, 2010 11:59 pm
Since updating to v1.2 I have not been able to play the following vid's
http://www.mirillis.com/forum/download/ ... view&id=51
Splash then crash's and I receive the message "Splash Pro has stopped working" and windows then attempts to search for a solution....
Fullscreen capture 9092010 91606 AM.jpg (17.23 KiB) Viewed 15570 times
Joco1114
Re: Problems playing XVID
Thu Sep 09, 2010 5:44 am
Have you ever try to play it with another player? Was it success?
Or an idea: try to install ffdshow. I know, Splash use internal codecs, but maybe it will works. (bad consistency...)
Joc
Home Theater:
Synology NAS 1010+ | 9TB HDD
Terry
Mon Sep 13, 2010 4:20 pm
Joco1114 wrote:Have you ever try to play it with another player? Was it success?
Joc
does not use internal codecs for xvid and thats a problem i guess :)
i watch xvids with splash (ffdshow installed) and it works nice
HFS10dude
Tue Sep 14, 2010 4:00 am
Thank you folks, installed ffdshow and all is working extremely good.
I forgot to mention that the problem only occurred on my notebook. My main comp didn't have the same problem when I updated to v1.2.1.0..........
Nevertheless thank you for solving my problem.......
