bcz
PC Specification: Windows 10
240 fps recording
Sat Jan 20, 2018 8:18 am
Hello there,
I love to record Minecraft and other games with 240 fps. It gives it a very clean look in Sony Vegas Pro 15. But, the fps cap for action is 120 fps.
I was wondering if you guys at Mirillis could at fractional fps recording to Action! It also helps with special motion recording.
Thank you!
Noah
Re: 240 fps recording
Tue Jul 17, 2018 6:44 am
Hello there,
Thank you!
Noah
Thank you for the suggestion.
aarondagreat
PC Specification: i7 6700k gtx 1050 ti
Make a 240FPS option
Sun Aug 05, 2018 4:24 pm
This has been suggested a lot but hasn't even been considered, if you honestly want to be on top with Mirillis Action you should add 240fps. If it wasn't for OBS being glitchy/horrible I would still be on OBS till this day since they offer you a 240fps option to record in. The reason why I want to record in 240fps is obviously because it makes videos so much smoother than 120fps. In my gaming community(minecraft potpvp) everybody, and I mean EVERYBODY, uses 240fps, but then they also use OBS which I don't want to use because Action has a simple design and its easy to work things out with it. Please make a 240fps option.
