icsterm
Contact: Yahoo Messenger
Splash 1.2.1 mkv playback problem
Mon Sep 13, 2010 1:27 am
I just tried to play an mkv file but i don't get any video on it, only sound. Seems like an bug to me, tried disabling Avivo and enabling overlay but no help.
Here is the sample for the developers/users to test:
Hope to get this fixed.
PS: also it doesn't show length of the movie unless i stop the non-working state playback.
Joco1114
Re: Splash 1.2.1 mkv playback problem
Mon Sep 13, 2010 4:47 am
I checked your problem. The results:
* with 1.1 nothing happened. No audio/video.
* with 1.2.x played audio only.
* with other player (AV codec: ffdshow) everything was OK.
I hope Mirillis can solve this (maybe codec) problem.
Joc
Home Theater:
Synology NAS 1010+ | 9TB HDD
BDX
Mon Sep 13, 2010 12:26 pm
http://www.mirillis.com/forum/viewtopic.php?f=18&t=413
Helios wrote:Hi all,
the issue has been fixed and will be resolved in neeres Splash update (comming soon).
Thank you all for very constructive and valuable feedback.
regards,
They promised the fix two months ago but failed to deliver.
icsterm
Thu Sep 16, 2010 8:35 am
Thanks for the tip ;) Hopefully next version fixes mkv files.
Mon Sep 20, 2010 2:24 pm
Please check Splash PRO 1.2.2, it should fix all problems.
