BorisVasilev
PC Specification: Windows 7 Ultimate x64
A few important features are still missing.
Mon Sep 13, 2010 10:14 am
Hi folks,
I'm a big fan of Splash PRO, but there are still some small features that are missing. The one is playback speed, and the other is smart stretch 16:9-> 4:3. Hope they could be added somewhere in the feature versions. :idea:
Terry
Re: A few important features are still missing.
Mon Sep 13, 2010 4:15 pm
whats smart stretch? im using mostly 16:10 but sometimes need to use 4:3 display too(or something about this)
BorisVasilev
Mon Sep 13, 2010 7:56 pm
Smart stretch is a feature that adjusts the portions of the picture, removing black lines on top and bottom.
Nielo TM
Mon Sep 13, 2010 8:02 pm
Hopefully they'll add in the short-cut menu, so we can switch between multiple AR on the fly
gmit
Mon Sep 13, 2010 8:34 pm
I would rather see Smart Stretch 4:3 -> 16:9 :D
Nielo TM
Mon Sep 13, 2010 9:06 pm
Smart-stretch destroys pixel definition and it distorts the image. It's better to crop
BorisVasilev
Tue Sep 14, 2010 5:40 pm
It's not better to crop because you loose portions from the picture. CyberLink PowerDVD stretches the picture without distorting it and it does not destroy anything.
Joco1114
Tue Sep 14, 2010 6:22 pm
BorisVasilev wrote:...stretches the picture without distorting it and it does not destroy anything.
You mean with a smart distorting. If you want to know more about it, here is a link:
http://broadcastengineering.com/mag/bro ... g_getting/
Home Theater:
Synology NAS 1010+ | 9TB HDD
Nielo TM
Tue Sep 14, 2010 7:52 pm
BorisVasilev wrote:It's not better to crop because you loose portions from the picture. CyberLink PowerDVD stretches the picture without distorting it and it does not destroy anything.
The majority of videos and compressed photos are essentially bitmap. So scaling/resizing will immediately result in lose of definition.
For an example, if you screen-print this page and resize it even by 1%, you'll notice that all the fine details have been lost.
gmit
Tue Sep 14, 2010 8:01 pm
That's not really true since smart algorithms will scale unfocused objects/background, while leaving focused objects intact.
