RoGeL777
PC Specification: INTEL CORE i5 GeForce GTX 1050 Windows10
Action se cierra y abre automaticamente
Sun Jan 28, 2018 2:09 pm
Buenos dias amigos, tengo el problema de mi Action que al usarlo se me cierra solo y automaticamente se vuelve abrir en ese bucle y no hay forma de pararlo, tengo que reiniciar la PC para detenerlo, por favor si me podrias ayudar con mi problema, Gracias.
Good morning friends, I have the problem of my Action that when I use it closes me alone and automatically it reopens in that loop and there is no way to stop it, I have to restart the PC to stop it, please if you can help me with my problem, Thank you
Re: Action se cierra y abre automaticamente
Thu Mar 01, 2018 7:17 am
Please try removing or moving to another location all your video files from your video output folder. Once your video folder is empty please run Action! and see if it's still crashing.
