Ovidiu
PC Specification: i7 7500U,AMD RadeonR7 M445, Windows10x64
Dell inspiron 5567 and splash 2.x.x
Tue Jan 30, 2018 8:16 pm
I recently installed Windows 10 Pro x64 on my Dell Inspiron 5567 laptop with latest drivers from dell support
After installing Splash 2.1 and trying to start the program it crashes with the following error :
Splash has stopped working
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available
Error log :
Faulting application name: Splash.exe, version: 2.1.0.0, time stamp: 0x59257400
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x00000000
Faulting process id: 0xb68
Faulting application start time: 0x01d3561e802aabde
Faulting application path: C:\Program Files (x86)\Mirillis\Splash\Splash.exe
Faulting module path: unknown
Report Id: 5ea760b0-ff6e-4ee8-8c62-9a5cf6504099
Faulting package full name:
Faulting package-relative application ID:
Re: Dell inspiron 5567 and splash 2.x.x
Fri Mar 02, 2018 6:52 am
Please report your issue to our technical support via support@mirillis.com.
Return to “Splash 2.0”
