computeur
PC Specification: i7 4790k, GTX 980, 24Gb 2133Mhz, SSD 500
Action undetected Facerig (Steam) after update
Fri Feb 02, 2018 2:41 pm
Hi
Today after the last Action update downlading it's impossible to use Facerig with it
Before (since yesterday) I had no problem both softwares works together.
But now I only have my camera (Logitech 920pro) iin the action selection menu!
already done: Skip facerig to Directx9
Uninstall and re install the 2 softwares
restart the computer (windows 10 64 pro)
Please can you help me
Thank you
Re: Action undetected Facerig (Steam) after update
Fri Jul 13, 2018 1:21 pm
Hi
Thank you
Please make sure that broadcast option is on in Facerig software.
If the issue persits then open FaceRig file location and go to Bin -> prerequisites and run the FaceRigVirtualCamDriver_win10.exe
