crl2007
ANNOYING BUG - MAYBE THIS WAY YOU FIX IT
Fri Sep 17, 2010 3:45 pm
There is still that annoying bug when you have multiple files in one folder. The first movie has subtitle, but when the second starts, the subtitle does not load. This is from the first version of Lite. There is no chance to fix this annoying bug ?
Re: ANNOYING BUG - MAYBE THIS WAY YOU FIX IT
Mon Sep 20, 2010 2:05 pm
fixed in PRO 1.2.2
