aviwil
Auto Play Problem
Mon Sep 20, 2010 12:47 pm
I installed the latest Pro 1.2.2 on my Vista 32 . On installation , I assigned all videos to Spash as default .
With vob and mt2s files , if I double click on them , Spash comes up , but doesn't play - if I click on the play button , it plays the last video that I played . If I bring up Splash first , and then do an Open of these videos , they play OK .
Re: Auto Play Problem
Tue Sep 21, 2010 4:09 pm
Hmmm, and whats happening when you right click on problematic files and choose "open with" nad choose Splash PRO?
aviwil
Tue Sep 21, 2010 7:17 pm
Thanks Ghost . For the mt2s , that works - for the vob , it's same ( doesn't work as above ) . I do have Splash Lite installed also - could this be a problem ? If I run Pro , and disable "Best Quality" , so it's then running similar to Lite ? If so , I can uninstall the Lite , and just disable the "Best Quality" when I need more performance , and it'll be like Lite ?
