zento
PC Specification: xps 1730, c2d t9300, 8700gt sli, win7 64
motion2 works great 5mn then...
Tue Sep 21, 2010 10:54 am
hi guys,
each time i play a mkv file with motion2 enabled, it works fine the first 5 minutes then it start to be choppy, same problem for the sound. If i disable the motion2 (even during payback), everything is running smoooth again. I could understand if it was choppy at the start of the playback, but it's not the case.
it happens with 1080, 720 and even sd files.
My drivers are updated and my comp is strong enough imho.
xps1730, c2d t9300 @2.5, 2x8700gt in sli, 6gb ram, win7 64
i bought splashpro especially for the motion2 feature so any help will be appreciated.
and sorry for my crappy english by the way ;)
cheers,
Zento
Re: motion2 works great 5mn then...
Tue Sep 21, 2010 4:23 pm
Thank you for reporting problem.
We will investigate this problem asap.
Can you check if problem repeats with "Force video overlay: option (settings/video)?
Does the problem repeat with hardware acceleration enabled/disabled?
zento
Tue Sep 21, 2010 6:04 pm
Yes, it still happen after ~5mns with force video overlay enabled
and with hardware acceleration turned off too
joeboy
PC Specification: I7 920, BFG GTX 295, windows7 ult 64
Wed Sep 22, 2010 5:08 am
Hello, i have same problem! it would freeze up for maybe 5-7 seconds then after sounds would cut out...it was fine before when first release...Im very impressed with this player..thank you..
resinate
PC Specification: Win7 Ult
Fri Sep 24, 2010 11:01 pm
its a global issue motion is OFFICIALLY BUSTED please post this on the main site until fixed pls, cuz right now thats voids the terms u guys have when u sell the products, i dont want to see this team get in big trouble over it.
theres been over 100 posts on this bug, u guys know whats causing pls fix this over any other thing before ppl start demanding money back.
Fri Oct 01, 2010 7:18 pm
Guys, please check latest 1.2.3 version as it has some fixes for Motion², and the feedback is very welcome.
Joco1114
Sun Oct 03, 2010 9:45 am
Ghost wrote:Guys, please check latest 1.2.3 version as it has some fixes for Motion², and the feedback is very welcome.
It is working for me now! No "chopping", no vibration, no hiatus.
Home Theater:
Synology NAS 1010+ | 9TB HDD
zento
Fri Oct 08, 2010 10:15 am
unfortunately, the problem is still there for me even with the latest 1.2.3 update.
I also tried different gfx drivers with no luck.
Helios
Fri Oct 08, 2010 2:24 pm
Hi zento,
I have some questions that could help us to reproduce the problem, because since your report we were unable to repeat it in our test lab.
- is there a scenario that you dont experience the issue?
- is it happening on older Splash Pro versions (1.0.0 or 1.1.0)?
- when it happened for the first time? maybe you remember what important could change in your system configuration, some driver updates, or a new software installed?
- could you check your CPU temperature before enabling M2 and once again when you experience the issue?
maybe there is something else you think can help us I didnt ask.
regards,
dyep
PC Specification: Windows 7 64 bit
Sat Oct 09, 2010 8:05 am
I can confirm that motion2 enabled still doesnt work correctly on my pc either even with the latest update 1.2.4
I have a Windows 7 64bit and enabled hardware acceleration. Graphics card is a dual nvidia geforce 9500 GT.
