caspadan
PC Specification: Win10x64, i7-4770K, R9-280x, 16G DDR3
mouse cursor incorrect position
Sun Feb 04, 2018 3:59 pm
OS: Windows 10 x64
Video Card: R9 280x + HD 7950
Memory: 16 GB
Monitor Resolution: 3840x2160
Video Type: MP4
Video Driver Version: 18.2.1
CPU brand and model: Intel i7 4770K
Motherboard brand and model: Gigabyte Z87X-UD3H
I'm just testing out the trial at the moment (v2.8.2.0), I notice with Active Screen recordings, the mouse is not in the correct postion (a bit higher and to the left). It was the same with the beta. Video size is set to original (but recordings are 1920x1080 and my desktop is set to 3840x2160. I tried changing the video size to 1080p but the same occurs. In game the mouse seemed to be in place. I only tested in PUBG, but the game is set to fullscreen mode and the resolution is 1920x1080.
Also, getting quite a knock on my FPS when recording..probably my oldish hardware.
Otherwise, I'm quite interested in getting this. Will a current license allow you to update beyond v2?
Re: mouse cursor incorrect position
Fri Jul 13, 2018 1:00 pm
OS: Windows 10 x64
Memory: 16 GB
Video Type: MP4
Please update Action! to the latest version and see if the issue persits.
