viperwolf
PC Specification: I7 4.3ghz SLI Strix OC 970s W10Pro
Detecting Game Issue
Wed Feb 07, 2018 3:26 am
Action works with my Steam games ( I have not tried Orgin) but it wont detect Forza 7. Is there a way to force it to recognize a game?
Re: Detecting Game Issue
Wed Mar 07, 2018 6:50 am
Try recording this game in Active Screen mode.
Thommy-L
PC Specification: Core I7 920, AMD R9 280x, Win7 64bit
Wed Mar 07, 2018 11:03 am
I can't get Action to work with ANY Steam games except Poly Bridge running in a window--not full-screen--. I've tried to get it to work in Witcher 3, Afghanistan '11, They Are Billions, and Ultimate General: Civil War. Action simply does not recognize any hothey input while any of these very diverse games are running. I'm assuming it has more to do with Steam than the games themselves.
I tried recording with Active Screen. I started Action, then Steam, and then started Witcher 3. Once I had loaded the Witcher 3 save I switched out to Action and clicked on the Start/Stop Recording button at the bottom center of the app, then switched back to Witcher 3. I assumed that Action was recording because the HUD icon changed from blue. I'm red-green colorblind, so I cannot say whether the icon changed to red or green, but it appeared that I was recording, at first anyway. Instead of the Action HUD showing AERO in the upper left, it showed DX, but the recording time did not advance beyond 00:00:02. After almost 8 minutes of recording I switched back out to Action. An overlay in Action showed 7:38 and continued counting until I clicked the Start/Stop Recording button again. When I replayed the recording, all that it had recorded was the time between starting recording and switching to Witcher 3, and switching from Witcher 3 and Action to stop recording. NO ACTUALLY GAMEPLAY WAS RECORDED AT ALL!!
Thommy-L
Sat Mar 10, 2018 4:00 pm
I have to report, I've got Action! working normally again. The issues appears to have be caused by Avast Internet Security having updated incorrectly. I believe AIS watching over Witcher 3 as a game (performance enhancement, which 'unloads' unnecessary programs from memory to speed-up gaming) might have blocked Action! from receiving hotkey presses while Witcher 3 was running, or caused it to be paged out and prevented it from paging back in and thus preventing it from running.
At any rate, once AIS was fixed (uninstall, cleanup, reinstall) Action! is working as expected again :D
burdenmark
PC Specification: Window 2016
Tue Jun 09, 2026 11:27 am
It sounds frustrating that Action isn't detecting Forza 7! Have you tried running the game as an administrator or checking if there are any updates for Action? Sometimes, adding the game manually to the software's settings can help it recognize the game. If all else fails, reaching out to Action's support might provide a solution.
davismark
PC Specification: Window 2019
Thu Jun 11, 2026 4:04 am
It sounds like a frustrating issue! Have you tried verifying the game files in Steam or checking if there are any updates for Forza 7? Sometimes, reinstalling the game or the detection tool can help as well. Let us know if you find a solution!
