Prizm
PC Specification: iMac 5K 2017, i5, Win 10, Radeon Pro 580
Display driver crashes when recording starts (5K monitor)
Wed Feb 07, 2018 9:43 am
When I start recording the "active screen", the whole screen will flash on and off a few times, and then Windows 10 will pop up with a message saying that the display driver failed to start. It then reverts back to a "basic driver". The program continues to record, but the resolution gets messed up, so I have to stop anyway. If I play back the video, it's choppy with frame drops.
I'm using an iMac 2017 with a 5K monitor (5120x2880). I have a dual installation, so it's running Windows 10. I wonder if it's an issue with ultra high res monitors?
If this helps, the OS treats the monitor like a dual screen setup. The left half of the screen is monitor 1, and the right half is monitor 2. When Action! crashes, Windows 10 resets to the "basic driver", and only the left half of the screen is displayed (it's not cropped, just an odd resolution). The right half is black.
Also, I appreciate that Action now has a 150% window size mode. But honestly, it could use some more at this resolution :) How about a 200% option?
CPU: i5 7600K 3.8GHz
GPU: Radeon Pro 580 (latest drivers, 18.2.1)
RAM: 40GB
Windows 10, latest updates installed
Action! version 2.8.2.0
Thanks
Re: Display driver crashes when recording starts (5K monitor)
Wed Mar 07, 2018 6:51 am
Try reinstalling or updating your video drivers.
