purplepj85
PC Specification: Windows Vista 64
Hang while streaming MTS file
Sat Sep 25, 2010 1:22 am
Two scenarios, one works, one doesn't and I'm not sure why.
Scenario 1:
I have an MTS file on the desktop of computer A. Splash Lite plays it cleanly on computer A.
Scenario 2:
I copy the same MTS file to the hard drive of computer B. Computer A has computer B's hard drive mapped as a network drive. If I try to play the file on computer A from the mapped drive on computer B, it plays about 2 or 3 seconds of the file and then freezes.
I have a high speed connection between the two computers and can cleanly stream large Quicktime (.mov) using the same scenario as 2 above, so I'm fairly certain it's not a bandwidth issue (and even if it were, I wouldn't expect Splash to hang).
Any idea why Splash Lite might run the file cleanly in scenario 1 and not scenario 2?
Thanks!
Re: Hang while streaming MTS file
Fri Oct 01, 2010 6:15 pm
Hi, what is this high speed network connection between PCs? (wifi/ethernet/gigabit ethernet)
