bellgenius
PC Specification: Win7 i5-4460 750TI
Hardware accelerated decoding
Fri Feb 23, 2018 6:17 am
My Graphic Card is GTX750TI now (not support H.265 Hardware accelerated decoding)
If I Change it to 1050TI (support H.265 Hardware accelerated decoding)
Do I have to change any setiing?
Re: Hardware accelerated decoding
Fri Jul 13, 2018 10:30 am
Hello, no need for changing any settings.
After you replace your graphics card the "NVIDIA NVENC HEVC" option should show up under hardware acceleration.
Return to “Splash 2.0”
