Malfunction
PC Specification: Windows 10 (Run via boot camp)
Cant Change Save Folder
Wed Feb 28, 2018 10:16 pm
Action
Action Version: 3.0.0 (Beta)
Recording Resolution: 1080p
Recording Mode: Game
Windows and Hardware
OS: Windows 10 (Run via Boot Camp)
Video Card: GeForce GTX 680MX
Video Driver Version: 391.01
CPU brand and model: Intel Core i7 3770K
Motherboard brand and model: Not Sure
Memory: 8
Monitor Resolution: 2560x1440, 59Hz
Problem Description
Game/App Problem: N/A
Error Type: Action Stops Responding and Restarts
Video Editor: Camtasia
Description: I open the beta and it defaults the file location to an external hard drive I am no longer using. (Assumedly because it has remembered my settings from a previous version) I try to change the file location and actions stops working and restarts itself. Tried multiple locations.
Re: Cant Change Save Folder
Wed Mar 21, 2018 7:05 am
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
6. Install Action! again. Make sure that your installer file comes from official website - www.mirillis.com
