nenco
PC Specification: Core i7, HD5730, 7 64bit
Audio HD not supported?
Thu Sep 30, 2010 7:55 am
Hello, my system satisfy this requirements:
AUDIO BITSTREAMING
S/PDIF or HDMI output is required
for audio bitstreaming.
HDMI 1.3 compatible output and
Windows 7 is required for HD audio
bitstreaming.
I can select hd tracks but no hd audio is output, just core sd audio
marfpilf
PC Specification: Windows 7 x64, E8500, ATI HD 5850
Re: Audio HD not supported?
Thu Oct 21, 2010 1:09 am
I have this same problem.
icsterm
Contact: Yahoo Messenger
Sun Oct 24, 2010 10:29 pm
Maybe your hdmi device doesn't recognize AC3/DTS codecs natively. Use stereo in this situation.
Wed Oct 27, 2010 9:17 am
Guys, please check the latest 1.3.0 version as it contains some improvements for HDMI audio bitstream with ATI 5xxxx cards.
marfpilf
Thu Oct 28, 2010 12:56 am
Catalyst 10.10 drivers (including hotfix 10.10c) using HDMI Audio driver from ATI results in no sound with Splash PRO 1.3.0 when trying to play Dolby TrueHD.
Also, I still cannot play DTS-MA through Splash PRO, only DTS.
Thu Oct 28, 2010 9:18 pm
marfpilf wrote:Catalyst 10.10 drivers (including hotfix 10.10c) using HDMI Audio driver from ATI results in no sound with Splash PRO 1.3.0 when trying to play Dolby TrueHD.
Does the problem with TrueHD repeat for all files?
Do you repeat a problem with various containers (mkv, m2ts...)?
We have the very same setup here (Win7 + ATI5850) and we can successfully bitstream TrueHD audio with HDMI output.
There can be problems with DTS-MA audio and if we detect problems we try to bitstream core DTS audio then.
marfpilf
Fri Oct 29, 2010 1:50 am
Thanks for the reply ghost.
I will try to put my TrueHD source in an m2ts container and see if that works and report back.
As far as the DTS-MA issue, is there a reason it always reverts to DTS whenever I play something? Could that be a container issue as well?
marfpilf
Fri Oct 29, 2010 3:02 am
Leaving the container as M2TS fixed the problem. I can now play TrueHD!
Now about that DTS MA :)
ciocia
PC Specification: Intel core2 e8300, vga amd 5770, seven64
Sat Oct 30, 2010 11:59 am
Hi, i'm sorry for my english but i don't speak english :oops:
Seven is necessary for audio HD, ok, but also hdmi audio output for the normal 5.1 ac3/dts?
I ave installed splash pro trial on my pc: winxp 32 (In the future i install seven64) vga amd 5770 connected to the denon avr2310 with hdmi )
I try a file test audio 5.1 .avi ( test signal for each individual case, useful to see if 5.1 works well ).
In setting/audio, if i select 5.1, audio is ok for all 5.1.
But if i select hdmi bitstream, the sound is bad:
The audio center speaker comes out from two fronts speaker
The sound of the 2 front speakers is ok
The rear speakers and sub are mute
Why? I should not select hdmi audio?
ciocia
Sat Oct 30, 2010 3:58 pm
I answer by myself: I installed seven64 and now HDMI output works correctly ;)
1-Where can I find an audio file to test audio hd? ( dolby true e dts hd )
2- If i buy splash pro, how long does the license? I will be able to update the program forever?
