xIHighVoltageIx
PC Specification: I7 5820k,MSI980TiGaming6G,W 10 64x Pro
Bug with MPC-HC
Tue Mar 06, 2018 6:59 pm
So i have a bug with all Versions of Action.
mpc-hc.org
If i have started with this player a Video and i switch video without close mpc-hc then i got no video only Sound. If i have close ACTION and switch then all works fine. Please check this
Re: Bug with MPC-HC
Fri Jul 13, 2018 10:41 am
mpc-hc.org
Tank you for contacting us. We will check that out.
Please update Action! and MPC-HC to the latest versions and see if the issue persists.
