helic
PC Specification: i7-4790, 8GB RAM, GTX 745, Win 10 x64
Live streaming problem
Fri Mar 09, 2018 6:51 pm
Hi, I have an issue concerning the live streaming.
Everytime I stream, after a while, it will stop abruptly and pressing CTRL+F9 gives me the problem you see in the following image. I am then forced to close the program because it wont responde, afterwards it will restart automaticaly.
Do you have some solution?
Thank you.
Re: Live streaming problem
Wed Jul 11, 2018 5:51 am
Thank you.
does the issue occur for every streaming platform? Maybe streaming service cuts you off because of incorrect streaming settings.
Try lowering the settings in Live Streaming tab.
