donny_444
PC Specification: Window 10
HUD NOT Showing up & mp4/avi can't recording
Fri Mar 16, 2018 6:15 am
Hi!, there is a big problem for my ACTION! .. :(
first , my computer's hardware is
1. Windows 10 Home 64Bit
2. VGA: NVIDIA Geforce GTX 1050Ti
3. RAM: 8 GB
4. CPU:i3-7100 3.90Hz
And , there are my problem
1. The HUD UI is not showing up .
whatever i press open/close HUD it's doesnt showing up.
2. MP4&AVI can not recording
when i try to record mp4 video , ACTION! does not output any file.
although it can output avi video , but it's nothing content in the output file and always just recording 1 sec.
3. Some function is not availible
Shift + F9 usually can pause recording , but now i can't
F6 usually can open/close HUD UI , but now i can't
the following solution i have try is :
1. Delete ACTION! and run regedit to clean ACTION! 's .
2. Reinstall ACTION!
but the problem still exist...
Re: HUD NOT Showing up & mp4/avi can't recording
Tue Jul 10, 2018 9:34 pm
You may try to open the task manager and select dwm.exe and kill this process so it would restart.
Please make sure that you have installed the latest 3.1.6 version of Action!
