Splash viewer
PC Specification: hp quad win 7 ultimate
Capture folder setting.
Wed Oct 06, 2010 2:08 pm
Where can i set the capture folder? For use with the C key?
I can not find the menu.
Thank you.
Joco1114
Re: Capture folder setting.
Wed Oct 06, 2010 2:45 pm
This function doesnt work for me, I get "Not available" error message. (nVidia)
I think there is NO folder settings option right now.
PS: Print Screen is working for me! :)
Home Theater:
Synology NAS 1010+ | 9TB HDD
Splash viewer
Wed Oct 06, 2010 2:51 pm
Joco1114 wrote:This function doesnt work for me, I get "Not available" error message. (nVidia)
PS: Print Screen if working for me! :)
I have it edited before.
I don't remember witch setting i have changed. :?
Joco1114
Wed Oct 06, 2010 2:56 pm
Maybe there is a config setting in the config file located:
C:\Users\your_username\AppData\Local\Mirillis\config2.ini
P.S: Capture mode is not working with Motion2. I read user manual! :)
Home Theater:
Wed Oct 06, 2010 2:57 pm
At the moment screen snapshots are always saved in "My Pictures" directory and files are named: "Splash PRO xxxxx.bmp".
There is no option to change this yet.
Joco: Disable Motion2, Snapshot is not available with Motion2 enabled.
Joco1114
Wed Oct 06, 2010 2:59 pm
Ghost wrote:Joco: Disable Motion2, Snapshot is not available with Motion2 enabled.
I got it! :)
Home Theater:
Splash viewer
Wed Oct 06, 2010 3:12 pm
I have changed it somewhere. I am 100% positive
All my captures was going to \ instead of My Pictures\
This morning was every capture going to \
I did a -cleanstart and now its going to my pictures\
I try to remember real hard what i have done, i its lost in time and space........ :x :x :x
It can be done, please help.
Splash viewer
Wed Oct 06, 2010 4:15 pm
I can not remember what i have changed.
Thus the hard way, change the registry reg:\HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders\My Pictures
i am 100% sure this is not done before but in splash, because this reg entry was default.
I am getting old.....
Apple Scruff
PC Specification: Windows7 Ultimate; GeForce 9600GT
Sat Oct 23, 2010 10:14 am
I wouldn't have thought that introducing facility for user-selectable 'capture destination' would be such a huge task.
Perhaps it'll be introduced in the next 'life' i.e. v2
icsterm
Contact: Yahoo Messenger
Sun Oct 24, 2010 10:31 pm
@developers
Maybe add a function to generate x screenshots of the video at y % of the total length. That should generate a 20 bmp files preview of the file. Just like MPC does.
