Shlomi
PC Specification: Gtx 740m*
Can’t capture from HD PVR 2 from cable box
Tue Apr 03, 2018 12:56 am
Hi
I have hauppauge HD PVR 2 that connect to it 3 devices: Cable box, Xbox one and Computer.
I use HDMI switch to select and capture from each of them.
I used until few weeks in hauppauge capture - software that made by hauppauge
Since you added support that enable capture from devices it become much easier and comfortable for me to use amazing Action! Software.
When I capture from Xbox one and pc it works fine - there is only a problem with my cable box
When I switch to my cable box in HDMI switch I only able to hear a sound of my cable box but I can’t capture at all - if i press capture it doesn’t create any file..
What can be the reason? It is maybe a bug in the software?
Thank you very much.
Re: Can’t capture from HD PVR 2 from cable box
Fri Jul 13, 2018 11:17 am
Hi
You may not be able to record from this cable box because of HDCP system.
