crl2007
Picture 2 issue
Sat Oct 09, 2010 10:13 am
Picture2 isn't working well on new generation video cards that have power management enabled. When Picture2 is activated, the card clocks constantly change from 3rd to 4th state causing little annoying stutters. Like for a few moments ( 40-50 ms ) the movie is in slow motion. I verified this with MSI Afterburner, because I didn't know why my movies play in slow motion over certain areas with P2 enabled and with MPC-HC play just fine.
nVIDIA ForceWare Clocks
Level #1 GPU: 50 MHz, Shader: 101 MHz, Memory: 135 MHz
Level #2 GPU: 405 MHz, Shader: 810 MHz, Memory: 324 MHz
Level #3 GPU: 405 MHz, Shader: 810 MHz, Memory: 1674 MHz
Level #4 GPU: 607 MHz, Shader: 1215 MHz, Memory: 1674 MHz
crl2007
Re: Picture 2 issue
Mon Oct 11, 2010 9:35 pm
I hope you're not going to ignore this. Because of this problem I reverted back to MPC-HC.
icsterm
Contact: Yahoo Messenger
Re: Picture 2 issue
Wed Oct 13, 2010 3:14 am
You can tweak this using Nvidia System tools to trigger a fixed GPU clock when launching the splash exe.
crl2007
Re: Picture 2 issue
Wed Oct 13, 2010 9:03 am
Yeah, but why do this, when a fix can be done for the player, so it will run smooth on every pc ? Why should the user be forced to install 3rd party software just to use a movie player ?
Re: Picture 2 issue
Wed Oct 13, 2010 9:51 am
Hi, we will take a look at this problem soon.
crl2007
Re: Picture 2 issue
Wed Oct 13, 2010 3:09 pm
Thank you very much and keep up the good work.
