r00ter
PC Specification: gtx260, Qcore@3ghz, windows7x64
bugs found ?
Mon Dec 21, 2009 7:19 pm
i am using the dl version 1.05.
1st.
i cant use the seek bar if playing an hd avc mkv file
edit :
it works with some files but it wont work with others codec and container are always the same... is may depend on the index of the file if seek is available ore not.
2nd.
no manual aspect control is possible. some videos are wrong scaled
3rd.
i cant find a way to adjust brightness and contrast manual.
i hope your motion estimation type will be as good as the one wich is available via avisynth and ffdshow. i am watching your player now a long time and if the pro version can make it better faster and with an higer quality than ffdshow/avisynth you will have one customer.
and also i hope you know about the way avisynth and ffdshow is working this out.
Re: bugs found ?
Tue Dec 22, 2009 2:23 pm
Hi r00ter, welcome to our forum!
r00ter wrote: 1st.
edit : it works with some files but it wont work with others codec and container are always the same... is may depend on the index of the file if seek is available ore not.
This problem is probably fixed and fix will be available in next Lite 1.1 release. Currently there is problem when seeking MKV files with corrupted/incomplete index.
r00ter wrote: 2nd.
3rd.
This features are not available yet, but both are scheduled for future versions.
r00ter wrote: i hope your motion estimation type will be as good as the one wich is available via avisynth and ffdshow. i am watching your player now a long time and if the pro version can make it better faster and with an higer quality than ffdshow/avisynth you will have one customer.
Our main target is "quality" and we hope to get really great quality here.
Performance should be much better as we are going to use both GPU and CPU.
We also care much about user interface and ease of use. Using Motion² will be as easy as enabling/disabling hardware acceleration in current Splash Lite - just one tick to select.
r00ter
Re: bugs found ?
Wed Dec 23, 2009 10:44 am
well, if you can manage that, i hope you can i will throw away my ffdshow 4 you.
but i think a few more post fx like : unsharp mask, levels, and film grain could be added by your team.
Re: bugs found ?
Wed Jan 20, 2010 11:58 pm
r00ter wrote:well, if you can manage that, i hope you can i will throw away my ffdshow 4 you.
Yes, we are going to add few basic picture controls.
